Kpro settings for LC and Overrun
WillP
Post by WillP »
Hey,
I have a couple of questions.
I have been working with the launch control settings for a customer with the anti lag settings
Fuel enrichment, no matter how much i put in, nothing changes. Is this conflicted by other settings/maps to gains the amount you enter?
Retard ignition, how is this entered? does entering 20 mean 20 degree retarded so -20 or are you to enter -20? Either way, Is this conflicted by other settings/maps to gains the control you enter?
The reason I ask is because the amount you enter never seem to be actually achieved so no real control on the anti lag launch for boosted applications?
I have also been working on the overrun settings by a customers request
Are the RPM settings locked axis to 3000 RPM?
Or does adjusting 'Overrun min rpm' work around this?
Kind Regards
Re: Kpro settings for LC and Overrun
Is this on a turbo vehicle?
Retarding the ignition means that you are reducing the timing. a negative value will cause it to add timing as you will be using double negatives.
I do not understand your other questions.
WillP
Post by WillP »
OK that's fine but either way, the entered amount of ignition angle is never met on the live data?
The second question, overrun top cam and low ca, RPM data is locked to 3000 max and not changeable when I am sure it was changeable before?
WillP
Post by WillP »
Spunkster wrote: Mon Mar 11, 2019 10:27 am Is this on a turbo vehicle?
This is what I am talking about, the RPM data it open to change on SManager.
Are these locked on KManager?
There is no image and I'm still unsure of exactly what you are referring to.
Is this a turbo vehicle?
WillP
Post by WillP »
Images are attached
