EP3 K20A2 fuel pressure
WillP
Post by WillP »
Hi,
Can KManager show fuel pressure data at all? I cannot see it if it does.
Also how is the stock fuel pressure regulated? Is it worth setting up a fuel pressure regulator just before the rail feed with or without a return line?
I am looking into this for an ITB conversion.
Re: EP3 K20A2 fuel pressure
There is not fuel pressure sensor from the factory. If you have a version 4 K-Pro you can use an analog pressure sensor to one of the analog inputs on the K-Pro board.
