Kpro-v4 PRA ECU voltage problems and sensors
jdouille
Post by jdouille »
Hello everyone !!!! sorry i'm French and i don't speak English
- Honda Civic type R ep3 EUDM 2002 K20a2
- Kpro V4 47125 ( instaled by CPL RACING )
- ECU oem 37820-PRA-E02 2030-300318 1L19
- Kmanager 4.3.6 ( on Windows 8.1 X86 )
- Mapped by HredMotorsport 242ch 226nm
- G101 ground hondata correct
- CAI diy 3'', intake manifold Skunk2 Ultra street, RH Piper (no cat today but cat 200cc when mapped) exhaust Piper 2.5'', Odyssey pc680, TPS Acuity, Deatschwerks 65C, Hondata Kpro V4
I have a problem, nothing has been touched on the car for 1 year and everything worked well, I just installed a decata but nothing affected the mapping, good car while today.
Symptoms:
- Engine have loss power, back fire exhaust, idle very hasardous and low but not all time, voltage fluctuation in Kpro BAT and Primary & O2 sensor.
When i press the clutch idle get down fast limite cut off engine, fuel pump relay is very very hot. Key OFF, at battery bornes i have 12.76v and key ON have 12.20v engine off of course.
New parts today:
TPS, idle cleaning with new seal, fuel pump relay (blue), fuel pump, ELD with no changement.
HredMotorsport.kal
test1.kdl
New Datalog shortly, I need your help !!!!!! thanks best regards
Re: Kpro-v4 PRA ECU voltage problems and sensors
Have you discussed this issue with your tuner?
jdouille
Post by jdouille »
He is in Asia to learn to map the new Honda 1.5l turbo unfortunately and CPL RACING do not help me from England.
Have you see the voltage fluctuation to Primary & O2 sensor ?
Best regards.
Have you tried re-uploading a saved copy of your calibration to the ECU?
jdouille
Post by jdouille »
I had to save the hred map on my computer. I tried to add the launch control and send it back to the ecu, it works, I see the changes but still the same problems.
Instaled a decata without modifying the map can damaged?
It's possible to reboot the kpro ?
You should try contacting your tuner for the original file they tuned it with and see if that resolves anything.
jdouille
Post by jdouille »
is it a map problem?
Because the problem us appeared suddenly without any change.
It's possible cause odyssey pc680 battery, even fully loaded ?
Most strange are Primary sensor at 0.00V with engin power !!! And voltage fluctuations.
jdouille
Post by jdouille »
I have new Datalog but it's so longer for forum arghhhhhhhhhhhh
Engine shut down 552rpm and O2 et SO2 are 0.00V what !!!!!!!
please help
