K20A2 EP3 European ITB base calibration question
WillP
Post by WillP »
Hi,
I will be working on a EP3 K20A2 I am fitting ITB's.
Hardware
ITB's
310 cc injectors
Full manifold back exhaust system
Stock cams
Are the base calibrations with KManager ok to work from with ITB or can a ITB base calibration be supplied to me at all?
Kind regards
Re: K20A2 EP3 European ITB base calibration question
What ECU are you using?
WillP
Post by WillP »
Kpro V4
What is the part number of the ECU you are using with the K-Pro?
WillP
Post by WillP »
Hi,
Just to follow this up, the ITB's fell through so this one can be closed.
Thanks!
