FB6 2015 and the check P0455 and P0456
dvergara
Post by dvergara »
Hi.
I have two honda civic FB6 2014 and the check P0455 and P0456 is generated every three or four weeks.
the two cars have RBC swap and this check is disabled in the tuning .. but still the check is generated
Here I copy the check images and the calibration that I am using
Re: FB6 2015 and the check P0455 and P0456
We are looking into this.
dvergara
Post by dvergara »
hi Hondata.. any Update ?
I have no updates at this time.
chambers805
Post by chambers805 »
I have the same issue as well its super annoying, I thought it was a legit issue and replaced the purge solenoid valve and the gas cap. Still didn't fix it, what a waste.
dvergara
Post by dvergara »
It's been too long to correct a software error ... !!!
Sometimes when you disable the error in the ECU if the operation is vital to the ECU it will still set the code.
dvergara
Post by dvergara »
okay. I do not understand .. jajaja
What would be the correct way to deactivate the error?
can you explain to me .. I am a systems engineer and softwarer.
I understand that a correction must be made so that the error no longer appears when the sling is deactivated
