reporting a possible problem
andyroosim
Post by andyroosim »
Hi, I'm just reporting something I noticed in the software. In the boost control section, when toggling between the mbar, bar, kpa, psi, kg/cm2 the "psi" value seems to be off. For example when a value of 1 is set for bar, the value of mbar, kpa, and kg/cm2 are consistent however psi shows a value of -0.19.
Re: reporting a possible problem
1 bar is not 1 atmosphere (1.01325 bar = 1 atmosphere)
Since psi is relative, not absolute, then psi = 1 bar - 1 atmosphere = 1 - 1.01325 * 14.6953 = -0.2
andyroosim
i see. thanks for the clarification.
