fk2 flashpro
nunoctr
fk2 flashpro
Post by nunoctr »
Hi hondata
Why don't we have the basic tables in the fk2 as the Fk8 flashpro like the maximum air charge table? it was much easier to tune with this.
Can you make a table to change the relationship between the throttle pedal and throttle plate (not the gear torque tables) because in the normal mode the fk2 have a big throtle delay.
Thanks in advance
Re: fk2 flashpro
Those tables don't exist in the FK2.
There is no throttle pedal to plate table. The Bosch ECU takes in about 1000 parameters, stirs them around and comes up with the throttle plate.
nunoctr
Re: fk2 flashpro
Post by nunoctr »
hard times to tune hondas...
but could you make an option to use +R without the stiffer suspension setting? This could be a great addition to fk2 flashpro because almost every owner wants the +R without the stiffer suspension for everyday use.
Bravo
Re: fk2 flashpro
Post by Bravo »
nunoctr wrote: Tue Mar 26, 2019 3:59 am could you make an option to use +R without the stiffer suspension setting? This could be a great addition to fk2 flashpro because almost every owner wants the +R without the stiffer suspension for everyday use.
I can second this request as I'm sure would many others ... is it possible Hondata?
