Pin A4 always on
ef8crxman
Pin A4 always on
Post by ef8crxman »
Hey all! I put a gsr in a 1998 Crv. Installed s300 v3 in a p28. I am getting 12 volts whenever the car is on at pin A4. Went in the test output section and when I hit the test Vtec output I get 14 volts.
Any help would be greatly appreciated.
Re: Pin A4 always on
Do you have anything wired between A4 and ground? If not the pin will float to near battery voltage.
