Kpro for EK build question
JDMCRX
Post by JDMCRX »
Hey guys ive done a bit of searching and kind of got the info i needed.
The car is a 99 civic SI
Engine K24a2 with a CRV trans with the TSX 6 speed
i have a base rsx wiring harnes and a PND ecu
I read that im going to have a issue with the 6gear lock out ? also speedo on the 99 cluster.
I have a friend who has a V4 in a PNF ecu , would the PNF ecu work with my 02-04 wiring into my 99 EK ?
Re: Kpro for EK build question
You will have to add the wiring for the reverse lockout and connect it to the secondary runner control output for it to operate. The PNF ECU does not have this control option.
