Cant connect to ECM via Kmanager
dcfoster15
Post by dcfoster15 »
Hello,
I have recently run into an issue with my Kpro modified ECM. Here is the hardware information to start:
2003 Acura RSX Type-S
SN:4904
Kpro Hardware version:2
Firmware version 2.02
Software version 4.3.5.0
ECU type: PRB – US RSX Type-S
While looking at the Information tab in Kmanager I see that its telling me the ignition is off, except that my key is turned all the way to ign(2) so it should read on. Is there any way to test or check if my ECM is bad or if my Kpro databoard has died on me? I cannot connect to my ECM and I cannot get my RSX to start. When turning the key to ign(2) I donot hear the fuel pump kick on. I know the pump still works because I ran a jumper to the power wire and it runs. I started it up today and it ran for all of a few seconds then turned off. Ran tests and the relays appear good so im really stumped on this.
Any help would be greatly appreciated. Thank you
Re: Cant connect to ECM via Kmanager
You should try your ECU in a known working vehicle to see if it runs in that vehicle. Also make sure that the immobilizer has been turned off in the calibration before uploading.
