RED BLINKING LIGHT
terryburns
RED BLINKING LIGHT
Post by terryburns »
I have a red blinking light on the s300 board now. I can't seem to get passed 4k rpm without it breaking up now. I do have my solid green along with the red blinking light. Does this indicate a problem with board or software?
2.6.8.0 is software version
its a p28 chipped ECU
Serial Number I am not sure where to find. I have a sticker with 42586 on it. Not sure if that is it.
terryburns
Re: RED BLINKING LIGHT
serial number of the s300 inside the ECU. 42586
- version of software 2.6.8.0
- the calibration
CRX.skl
- a datalog of a problem. Don't have one
- what sort of vehicle you have. 1990 Honda CRX Si
- what sort of ECU you are using. P28
FIC 750 injectors, 50 trim ebay turbo, Exhaust out the hood, walbro 450 pump, ZC single cam with a y8 head
Car breaks up real bad at 4k rpms, like boost cut or something but that is all set high to avoid cut. Changed out fuel injectors same issue. Timing is dead on 16 degrees.
crluver123
Post by crluver123 »
Did you change anything in the tune?
Has the car ever ran well?
Did the problem start after you updated SManager to version 2.6.8?
terryburns
No tune change
Car has ran excellent yes
No it started one releases ago. And has never ran right since then.
The red light seems to be Hondata Software related, I can either unplug the computer from data cord or simply just close the program. The light will shut off at that point but car still runs terrible.
Do you have on-board datalogging turned on?
terryburns
No we don't, should we?
Is J12 cut on the ECU?
terryburns
It turned out the car running wierd was the fuel pump failing. Put new pump in and runs fine but still have red blinking light.
terryburns
Spunkster wrote: Tue Apr 02, 2019 3:04 pm Is J12 cut on the ECU?
I don’t see a J12 on the board.
J12 is near the 2 vertical boards.
