2016 CVT/w oil dilution update PROPER PROCEDURE
Rush
Post by Rush »
I've had my oil dilution update done and I've loaded the Civic Turbo 2016 +6 psi high octane tune to the ECU. Received an emission error on first try second attempt all good. I used Manager 3.2.8.0. So I'm assuming this is the correct tune? What is the correct return to stock procedure with the new Flashpro Manager version?
Re: 2016 CVT/w oil dilution update PROPER PROCEDURE
When returning to stock it will give the option of returning to a 16 or 17. You must return to stock for a 17 if you have the update from Honda, but if you do not you must use the 16.
Rush
Post by Rush »
Thanks.
