K20 no start with correct injector sizing
K20RX7
Post by K20RX7 »
Hello there,
PRA ECU Uk Type R K20A2 engine fitted to my Mazda RX7.
Im having an issue where if i try and start the car with the actual 1000cc injectors fitted it cranks and fires but does not catch.
If i reduce the injector sizing in the kpro to the stock 310cc injectors it starts and runs.
Im using a rising rate fuel pressure regulator set to 45psi.
If i tap the throttle the car cuts out.
Why wont it start and run with 1000cc in kpro settings.?
Look foward to any help. Map attached
K20RX7
Re: K20 no start with correct injector sizing
Post by K20RX7 »
attach
AREA876
Post by AREA876 »
Did you set the dead time for the injectors you are using
K20RX7
Post by K20RX7 »
Hello there.
Yes.
Deadtimes are accurate, they came with the set of brand new injectors. I found out later today that for some reason the hondata isn’t reading map sensor. Even when sensor and loom unplugged. It shows -29psi at all times.
Not sure if it’s a bug or if there is a fix for this
HAs the map sensor wiring been modified or touched in any way?
