Flash pro can’t connect to ecu lights crazy on dash no start
Huma
Post by Huma »
2012 civic si. Flash pro sees obd2 but not ecu. Checked all fuses there good. Lights on dash going crazy brake tpms charge so on. Battery is full charged turns over won’t fire up. Any advice is ecu fried. Also flash pro isn’t seeing my sons trucks ecu. It does the same the just a slow flashing green light. Lab top sees flash pro obd2 but not ecu.
Re: Flash pro can’t connect to ecu lights crazy on dash no start
Try unplugging the O2 sensors and see if the problem goes away, If it does then you have a short in the wiring of the o2 sensors.
Huma
Post by Huma »
SO I WAS CHANGING MY BATTERY AND POSTS. THE 2 WIRES ON THE NEG CABLE GOING TO THE CHARGE SENSOR. THEY GOT GROUNDED WHILE THE CAR WAS RUNNING. AFTER THAT CAR NEVER STATED BACK.
That would have been good information to include in the first post. It sounds like you have damaged something in the vehicle and may have damaged the ECU. I would recommend putting your ECU in a known working vehicle and then see if the FlashPro will connect and allow you to return to stock and unlock it.
