Kpro bug? Map sensor not functioning
K20RX7
Post by K20RX7 »
hello,
at first i thought it was an injection problem but turns out my map sensor is fully in vac.
dosnt matte what sensor i use nor if i pull wiring out of plug it shows neg 29psi..
is this a bug?
i just done an update
cheers
Re: Kpro bug? Map sensor not functioning
Not a bug. Are you sure the map sensor has not been damaged, the ECU 5V output is ok, and that your sensor setup is ok?
K20RX7
Post by K20RX7 »
Hello thanks for the reply.
I believe the TPS and map sensor plugs have been swapped by mistake. Could this cause it?
5v on feed. 4.7 on signal 0 on ground
All without map sensor plugged in.
Even with sensor unplugged it’s showing -29.
Running ktuned 4 bar. Have omnipower / hondata 4 bar selected.
I’ve tried resetting etc but didn’t help.
If you can, measure the voltage at the ECU with the MAP sensor plugged in.
Have you swapped the plugs back to the correct locations?
