P0171 with 3.5" SRI
Qyota
P0171 with 3.5" SRI
Post by Qyota »
Hello - first time poster.
I have a 2006 Civic Si with a 3.5" K-tuned SRI, and cat-back exhaust. Otherwise stock. I have uploaded the AFM-based map for the AEM SRI, figuring it would be "close enough". I've taken a few drives and datalogged, and the short and long fuel trims are off the charts. Short term was 25% or more, and long term pegged at 25%. So the ECU thinks there is much more air than there is, and is loading fuel to compensate. Instant-MPG reads high, when actual MPG is low.
Got code P0171 today - system too lean.
This car has a new MAF (stock DENSO), new A/F meter (DENSO), and downstream O2 sensor (DENSO). Is it better to alter the AFM calibration table, or switch to a MAP calibration for this intake in particular?
Also, knock count on cylinder #2 seems high...30 knocks in a 15 minute easy trip home (no VTEC, short-shifting, etc). No other cylinders are showing any knock counts.
I have attached a datalog for that 15 minute ride home if anyone wants to see it.
Thanks for your help!
Q
Re: P0171 with 3.5" SRI
It really depends on the person tuning. You can try tuning via MAP and see if that works better for you.
Qyota
Post by Qyota »
I think I'll try a MAP calibration, thanks.
I'm also trying to find a used stock/OEM air intake for this car. It's been harder than I figured it would be.
Qyota
Post by Qyota »
Uploaded the MAP-based calibration for an Injen SRI, and noticed immediate improvement in A/F and fuel trims. Car runs and drives MUCH better with this change. I'll drive it a few more days watching and datalogging, and then get to the tuning.
Qyota
Post by Qyota »
Day 2, so far so good. Fuel trims are normal, A/F is good, if not a tad rich especially during 1/2 - WOT. Start-up fueling seems a bit "off", especially when cold. Car takes at least one more crank cycle to start, and then sort of stumbles to life. Warm starts are good.
jcauto
Post by jcauto »
When intake shopping, I found a lot of companies specifying that any of their intakes over 3" in diameter need to be speed density tuned. Remember that the MAF is only reading a sample of airflow and the ecu is calibrated to determine how much air is actually entering the engine based on intake design. If there isn't a pre-made tune for your exact intake, these are the troubles you'll encounter. I disagree with using an AFM tune on any car, the best all around results I've had in both WOT and part throttle driving has been with a MAP tune.
