Ignition timing dropping after VTEC crossover
Juncura1
Post by Juncura1 »
2000 S2000
KPro4
Hello,
I'm tuning an AP1 S2000 and I'm having an issue with ignition timing dropping at the VTEC crossover. The tables call for 29° on the high cam, but I'm only seeing 18° in my logs. It will slowly climb util red line, but it's no where close to the table. I've also tried running really conservative timing with the same results... As soon as VTEC engages the ignition drops to 18°. I've checked the logs and I'm not seeing any knock, but I know I'm missing something.
Amy ideas?
Re: Ignition timing dropping after VTEC crossover
Post your calibration and a datalog showing the issue.
Juncura1
Post by Juncura1 »
I figured it out.
Thank you.
Typersam
Post by Typersam »
What was the issue bro
Juncura1
Post by Juncura1 »
It was a corrupted tune. I reloaded my base tune and it took care of it.
