problem with jrsc
partizano
problem with jrsc
Post by partizano »
Engine stock + jrsc. There is a problem with afr on WOT. The beginning is rich, then AFR goes to 14.4-14.5 for boost. No AFM, only MAP. Other basemap with AFM this same situation.
Where to look for a problem?
Time 0:27 - 0:28
Re: problem with jrsc
Have you relocated the MAP sensor so that it can see boost?
partizano
Post by partizano »
Flashpro manager displays boost
R-12914
Post by R-12914 »
Can you post a datalog, please!
2008 Honda Civic TypeR FN2
ECU: 37820-RSP-E02
Flashpro: FP-SI-INT-21153
Software: 3.6.1.0
Firmware: 185
partizano
Post by partizano »
startnew.fpdl
startnew.fpcal
The fuel tables are a mess. Only the 0 degree table has been altered, and then in a bad way.
partizano
Post by partizano »
Yes, it's for the test, but increasing the fuel has no afr change in the boost around 0.3bar or more
Check your fuel pressure as it looks like it may be dropping.
I'm fairly sure you're only changing the 0 degree table, not all of them.
partizano
Post by partizano »
Yes, but all cells in vtc low cam are set to 0
partizano
Post by partizano »
fuel pressure 3,2-3,3bar hi-load, low load 3.5
each vtc setting (15 *, 30 *, 40 *) is the same. About 0.3 bar arf increases
partizano
Post by partizano »
problem solved, o2 sensor damaged, the external sensor 02 displays the actual values on all vtc and boost
