Cpr misfire and quit running
DanHa1031
Post by DanHa1031 »
CPR ran fine for a mile or two then randomly misfired and died. Won't start back up or anything, swapped my buddies unit in, car fired right up and drove it home, put my unit back in and I've got nothing?? Can a cpr unit just quit working like that?
Re: Cpr misfire and quit running
Open it and see if anything is burned inside.
DanHa1031
Post by DanHa1031 »
The U4 latch has a slight brown spot on it.
Post a picture please
DanHa1031
Post by DanHa1031 »
Check your wiring, especially the COPs. The CPR has got +12V through the coil wiring, reverse polarity or a ground is bad.
DanHa1031
Post by DanHa1031 »
Wiring is correct, if cop wiring was bad it was out of the box that way, thermostat housing ground is correct, ecu wiring is correct, car has been running fine since January. This was sparatic misfire and then it just quit running.
Send an email to support <at> hondata.com with the following and I will issue an RMA and give you further
instructions:
Name:
Address:
Phone:
Email:
Serial#:
Description of problem:
Include a link to this thread.
oranged3mon
Post by oranged3mon »
I just had this exact same thing happen to me shop checked all the wiring it is correct
The only way this can happen is a wiring fault.
DanHa1031
Post by DanHa1031 »
Not true, mine failed because the chips were shaved too thin when the mfg tried to de-brand them. Had nothing to do with wiring or placement. It was poor mfg quality
