Re flash Check
Parrot45
Re flash Check
Post by Parrot45 »
37820-PNF-A12
197905-4120
There was a different number where the plugs connect to.
37820-PNF-A12
197905-4112
Thank you.
Re: Re flash Check
Yes it was reflashed.
Parrot45
Re: Re flash Check
Post by Parrot45 »
Thank you. Are you able to tell what the re flash consists of? And should I be running 91 octane fuel.
Thank you again for you help.
Re: Re flash Check
We only offer one reflash for that ECU and you should always use 91 octane with a reflash.
https://www.hondata.com/products/reflas ... 2?filter=7
Parrot45
Re: Re flash Check
Post by Parrot45 »
Thank you.
