Gear on display
autox19
Gear on display
Post by autox19 »
I have an LS transmission, and I dont have anything from it going to the ecu. so I would expect it to not show anything in the gear selection on the display in Smanager. What I find is it switches 1-5 pretty randomly. sometimes staying "in a gear" for 5-6 seconds, sometimes a blip. Should this be of concern? I am not having any setting change with the gear selection.
Odie
Fiat X19 with B16
Re: Gear on display
Do you have a working VSS?
autox19
Re: Gear on display
Post by autox19 »
Yup yup. Vss works perfectly.
Odie
Re: Gear on display
Post your calibration as well as a Datalog showing the issue.
autox19
Re: Gear on display
Post by autox19 »
here ya go. this is NOT a tuned calibration. Just getting things going.
Odie
Re: Gear on display
Make sure you have the correct gear ratios selected in the gear compensation tab.
autox19
Re: Gear on display
Post by autox19 »
Ok. But not sure what that would have to do with gear selection when there is nothing from the trans to the ecu.
Odie
autox19
Re: Gear on display
Post by autox19 »
Unless..... it takes the vss and the rpm going back through the gear table to figure out what gear it is in.
Very cool..i will try that when/if it stops raining. (Not a wet weather car)
Odie
crluver123
Re: Gear on display
Post by crluver123 »
autox19 wrote: Wed May 01, 2019 5:12 pm Unless..... it takes the vss and the rpm going back through the gear table to figure out what gear it is in.
Odie
yes that is all the ecu uses to determine gear: VSS compared to rpm, using algorithms determined via the gear ratios and final drive ratio.
