question about PLX wideband
ochumi
Post by ochumi »
hi i have a PLX wideband
i put wideband on d10 ELD narrowband on d14
the question
i have to disable heater o2 on hondata because the PLX module order that? because i don´t have to connect to pinout from ecu
wich mode i have to use for close loop¿? wideband (only for tune??, always) or narrowband
Re: question about PLX wideband
You do not need to have the narrow band signal hooked up. You can run closed loop from the wideband input in D10. You should disable the heater error.
ochumi
Post by ochumi »
I can disable the heater error here, can´t i? because the heater of the o2 works with the PLX module, doesn´t it?
Yes, once you are using something other than the factory narrowband the o2 heater is not used.
