Confirm that ECU is Jail-broken
Civicboi_fk2
Post by Civicboi_fk2 »
Hi Hondata,
My car is currently tuned (non-Hondata), i have since bought a flash-pro to enable my car to be tuned with Hondata.
Is there an easy way to ensure that my ECU is Jail-broken / ready to take a Hondata tune.
Car is a 2015 FK2
Regards
David
Re: Confirm that ECU is Jail-broken
You can try to use the FlashPro and if it does not work then it must not be jailbroken.
Civicboi_fk2
Spunkster wrote: Mon May 06, 2019 9:59 am You can try to use the FlashPro and if it does not work then it must be jailbroken.
Thank you for your reply. I can datalog with the Flash Pro is this enough to confirm? or should i try to upload a calibration. I am unsure of the calibration is on the ECU but do not want to loose it until i have a tuning session arranged.
Regards
Civicboi_fk2
Hi Hondata again,
I tried uploading the stock calibration and failed due to the ECU not being jail-broken which confirms my original question. However when it has failed it has put the ECU in recovery mode.
In the help files it says to re-upload the calibration however i cant due to the ECU not being Jail Broken. I have left the Battery disconnected whilst i go to bed to hopefully rectify this.
Any other advice?
Return the ECU to stock.
Civicboi_fk2
Hondata wrote: Tue May 07, 2019 11:07 am Return the ECU to stock.
Hi Hondata, Just for the closure of this thread, returning the ECU back to stock resolved the problem. Many thanks for your help.
William.Y
Post by William.Y »
I have same problem here with an FK8, how to return the ECU to stock?
Go to the online menu and click on return to stock.
