Flashpro Help - "Unknown Vehicle" and cannot see VIN
Blulude98
Post by Blulude98 »
Flash Pro Serial FP-TSX-US-90305
TSX ECU: 37820-RBB-A71
Having a problem to connect TSX ECU with Flashpro.
Have recorded VIN in ECU but cannot upload any calibrations or connect to FlashPro.
Attached below are the error messages.
Vehicle Model: Unknown
Vehicle Family: Unknown.
Cannot see VIN no in History tab??
What am i doing wrong?
Please help.
Blulude98
Re: Flashpro Help - "Unknown Vehicle" and cannot see VIN
Post by Blulude98 »
What vehicle is this being used in? What is the ECU part number?
Blulude98
Post by Blulude98 »
TSX ECU: 37820-RBB-A71 is being used.
Vehicle that i am using is a Australian 2004 Honda Accord Euro.
I believe that it does not recognize the part number. Use 'send support information to Hondata' and we will see.
Blulude98
Post by Blulude98 »
information has just been sent to Hondata support as requested.
The ECU is not reporting a calibration ID nor part number so the FlashPro cannot recognize it.
Blulude98
Post by Blulude98 »
Ok so does this mean I have a issue with the flash pro unit or the ecu?
Also what do I do to fix the issue?
It is the ECU. What's the full story - vehicle, origin of the ECU, any changes to the ECU etc.
Blulude98
Post by Blulude98 »
No story to tell actually.
TSX ECU came from a stock standard Accord TSX from the US which still runs the car fine.
What do i do next to resolve this issue?
If the ECU runs the vehicle, has the immobilizer been matched or disabled?
Blulude98
Post by Blulude98 »
Yes the immobilizer has been matched and it is starting the vehicle.
datalogging also works when flashpro is connected.
just cant upload a calibration map.
The ECU is not reporting a calibration ID nor part number. That is the problem.
Blulude98
Post by Blulude98 »
How do i make the ecu report a calibration ID and part number?
It is either the FlashPro, wiring or ECU. The FlashPro is reading the battery voltage and VIN, so it looks ok. Likewise the wiring is ok since the FlashPro can read the previous two items. However the FlashPro cannot see the ECU serial number which it needs to determine what the ECU is. So it most likely is the ECU.
The next steps to narrow it down would be to the FlashPro into another vehicle and check that it recognizes the ECU and /or use another ECU on you vehicle.
People disable the immobilizer by altering the ECU, which also disables the serial number, which is why I asked about the immobilizer.
