S300 V3 Uploaded base map wont Run
outsidematt
Post by outsidematt »
Recent purchase Of s300 v3. Pre socket.
sn37852
sofware version 2.7.2.0
Honda b16b with a OBd1 harness which then goes through a conversion harness to OBd2
History car run fine on original honda ecu
However with s300. is doing a strange thing. when the ignition is turn on the IACV in engine bay will humm. I can connect a laptop and can upload a base map however car will just idle at 2000 rpm. Any kind of throttle engine runs rough. I get the impression the map. though uploaded is not running and the only reason it is revving at 2000rpm is because the IACV is powered right open ( so to speak)
I also can not seem to do any kind of data logging..
Any kind of help would be grateful.
outsidematt
Re: S300 V3 Uploaded base map wont Run
Slight error its a OBD2a harness which then goes to a OBD1 conversion harness
What vehicle is this in?
outsidematt
This setup is not in a honda vehicle as such. It is in a rally car. It also runs JDM instrument panel which all works correctly.
Also to note. With ignition on I can not connect via Bluetooth either with a laptop or hondata mobile app. However if the ignigtion is on and the usb from laptop is connected, i can pair the mobile app. The apps only tell me the ignigtion is on but no data from sensors.
regards Matt
I would recommend that you try this ECU on a known working vehicle and see if it works as it should. If it does then it means that there is a wiring issue in your vehicle and will need to correct that.
outsidematt
Finally have got it fixed.
In then end the company who sold the ecu replaced with a different s300 board which fixed the problem. Every works as it should.
