cel 15
4doorcivic16
cel 15
Post by 4doorcivic16 »
hey, I recently bout s300 v3 for my b20 vtec set up 98 civic ex. I'm getting a code 15 for ignition output single I have checked and changed distributor, coil, and ignitors 2 to 3 times with known working ones and ignitor is still not signaling coil, also tried s300 in another car same thing but if I put a p30 in the car I get spark. what am I doing wrong here?
crluver123
Re: cel 15
Post by crluver123 »
code 15 is typically a bad ignition switch. On rare occasions it can be the main relay or the ecu itself.
Test your s300 board in a different known working ecu and see if you still get the same problem. If not, the ecu itself is damaged and needs to be repaired or replaced.
Re: cel 15
More than likely it is the ECU itself. Try your s300 in a different ECU and see if the problem goes away.
