PS Pump Switch - E16
AngryScottish
Post by AngryScottish »
ECU: KPro V4
Before I go about reinventing the wheel (pun not intended), I have a Mini Cooper EHPS pump installed. It currently runs whenever the ignition is on. After fiddling with some wiring diagrams... I noticed that pin E16 is for the PS Pump switch...
I'm not sure how the original system functioned, so sorry if this is remedial. But, could I use that to control my EHPS pump, by wiring that to a relay to power the pump on/off?
Re: PS Pump Switch - E16
No, that is an input to the ECU to idle up slightly when the pressure increased to keep it form stalling the engine.
AngryScottish
got it, thanks for the super quick reply!
