Engine cranks but it doesn't start
TotoRacingSerbice
Post by TotoRacingSerbice »
Greetings.
We're using a KPRO on a KMiata build and we can't get the engine to start. We have spark and fuel. I've attached to the post the kal and logs. The ECU is registering a P1361 DTC. The engine was rebuilt and the timing was checked and rechecked.
Help?
Thank you.
TotoRacingSerbice
Re: Engine cranks but it doesn't start
The ECU was tested on another car and the engine started.
You need to follow the troubleshooting steps for that error code (Factory service manual) and that will help you determine where the problem is.
