Throttle tip-in missing?
BrokeBoisCivic
Post by BrokeBoisCivic »
Hello!
I've got a FlashPro for a 2012 Civic SI. Currently running FlashProManager version 3.3.7.0.
I can't seem to find throttle tip-in parameters in the throttle section. Was this removed at some point? Is it not supported for the 2012 Civics?
I've attached a screenshot and the calibration that is currently on my car.
Thanks!
Re: Throttle tip-in missing?
ECUs are different between vehicles, so if you're looking for something from a different model then the 2012 may not have the same ECU logic or the same tables.
BrokeBoisCivic
Odd... If there is no throttle tip-in parameters, does that mean I'm stuck with it going lean for a little? How is throttle tip-in calculated (if at all) if there is no throttle tip-in parameters?
