Misc - VSA
R-12914
Misc - VSA
Post by R-12914 »
Hi Hondata,
what happens if I deactivate the hook on VSA even though my vehicle has VSA?
Is the VSA then switched off by default (every time the vehicle is started), which is the same as if I pressed the VSA switch?
Or is there any malfunction?
Look here:
2008 Honda Civic TypeR FN2
ECU: 37820-RSP-E02
Flashpro: FP-SI-INT-21153
Software: 3.6.1.0
Firmware: 185
Re: Misc - VSA
If your vehicle still has VSA then you should not disable this. This is only for vehicle which have completely removed the VSA system.
