U0038 after flash
Civic 2016+ 1.5 Turbo
lamyun
U0038 after flash
Post by lamyun »
FlashPro Manager 3.2.6.0, Firmware 156
2016 Civic EX-T Canada CVT
Issue: Got Error U0038 after updating flashpro to the versions above (last time it was used was 1+ years ago) and uploading +6 basemap.
Got "christmas tree" of error lights on the dash that won't go away.
From browsing the forums, it appears that it is a mismatch between the tune and the TCM. I do not have the fuel dilution update from Honda.
I would prefer not to bring my car into Honda to get the update as they will then know the car was modified/warranty issues/etc.
Question: Is there a way for Hondata to include the older 2016 Pre-fuel dilution map/tune, so I can at least clear the christmas lights??
As an end-user, there was no warning before flashing. If I had known I would have returned to stock and get the fuel dilution update beforehand.
Thank you for your assistance.
Re: U0038 after flash
First update to the latest version of FlashProManager.
If you do not have the oil dilution update from Honda (specifically when they reflash the transmission) then load a 2016 calibration, not a 2017 calibration, and you won't get the error.
lamyun
Post by lamyun »
Thanks for your prompt response!
I updated FlashProManager from 3.2.6.0 (FW 156) to 3.4.0.0 (FW 163) and successfully loaded +6 map. Car is back to normal. What a relief!
In 3.4.0.0, I was able to select the 2016 Civic CVT Calibration.
I do not believe this option was available in the 3.2.6.0 build (Only the 2017 Civic was selectable)
