Where do retrofitted ABS sensor wires need to go?
Listerofsmeg
Post by Listerofsmeg »
Hi,
I dont think this has been asked, i have checked a lot of threads on here for similar questions.
If i were to retrofit ABS sensors on to my car, where do i send the wires? as i wont have the control unit and my loom is 100% custom, so there is no loom to plug them in to etc. Is it simply a case of power from the TC module and a ground to chassis?
I have EK9 front and rear hubs, so OEM sensors will bolt straight on, but after that.....what would i need to know? (Assuming i were to purchase the Hondata TC module).
Thanks,
Neil
UK Time Attack EK Civic
B18 Turbo
Re: Where do retrofitted ABS sensor wires need to go?
Have you read the info in the traction control help file:
http://www.hondata.com/help/tractioncon ... wiring.htm
Listerofsmeg
great! Sorry i should have spotted that on the site.
So basically a 12v feed to the sensor and grounded via the module per sensor. Perfect.
B18 Turbo
