Something is very wrong with my s300
Supertramp
Post by Supertramp »
Can anyone tell me what is happening in this data log I recorded at idle?
trevors lean datalogging0618.s3d
Re: Something is very wrong with my s300
Please describe the issue you are referring to and include your calibration.
Supertramp
This is a stock p28 ecu calibration with 450 injectors on a d16 z6 engine with high compression pistions. My first concern was adjusting afr, I've tried adding overall fuel trim (10, 20, 40, 60,) with no success, still lean. Now I'm trying to figure out what is going on with my graph, sensors, error codes, ect...
When did this problem start?
Supertramp
Version 1.4.5.0
S300-2545
I also realized my green led is flashing red. That would indicate I need the v3 upgrade??
Your software is VERY out of date. Start by downloading the most recent version of software from the software section of the website and see if that allows you to upload and make changes.
