Error code 1 and 6?
Listerofsmeg
Error code 1 and 6?
Post by Listerofsmeg »
Hi,
So i purchase the TC product and have begun the installation. I powered up the until before hooking up any of the ABS sensors just to make sure i had the software installed correctly etc...However it is showing two error codes straight away....
Code 1 Control switch input out of range
Code 6 Hardware failure
The second of these sounds rather serious for what should be a brand new unit!!!
Can anyone advise? Will i get those errors until the sensors are hooked up??
Thanks.
UK Time Attack EK Civic
B18 Turbo
Re: Error code 1 and 6?
I wouldn't worry about any errors until you have it all installed and setup correctly.
Listerofsmeg
Ok thanks, i got rid of code 1 as i hadnt plugged in the dial! haha...
Ive got the front 2 sensors hooked up and was looking at the TC window in smanager, however on the parameters tab there was nowhere to select the TC input as ELD? its wired in to the correct pin but the option is greyed out and unselectable....
The live data isnt showing any activity either, is this normal?
B18 Turbo
Listerofsmeg
Update, errors gone, but there isnt much activity on any of the screens? the car is currently jacked up so when running the front wheels are turning slowly so i would expect some readings?
B18 Turbo
Listerofsmeg
ok solved the greyed out section too....
Are there any "expected" readings from a set of OEM sensors i can use as a base to know if this is working correctly? I have no controller, so theyre wired directly to the TC module.
B18 Turbo
