engine is gone because INJECTOR CUT IN 1 secound on high boost 7000 rpm , please help
payam_fox
Post by payam_fox »
hi , im trying to figure this out , when i do full throttle under boost more than 10 psi the afr reads lean around 7k rpm twice , i have datalog when i look at it injectors stop working in a spot , no matter how much fuel i have in the table , i have attached the datalog and map , please help the head gasket is already gone i was doing a pull to record datalog and see the problem , and boom on 3rd gear i blew the engine
Re: engine is gone because INJECTOR CUT IN 1 secound on high boost 7000 rpm , please help
Are you using a strain gauge?
payam_fox
Post by payam_fox »
no im not using
Why do you have it enabled in your calibration?
payam_fox
Post by payam_fox »
i actually havent noticed it , is that why its cutting fuel ?
probably
