Vacuum / Pressure in Tables
DaX
Post by DaX »
Am I just misunderstanding it, or are the vacuum columns in the tables going in the wrong order? Shouldn't column 1 be -29.1 (in-Hg), and column 9 be -3.8?
Re: Vacuum / Pressure in Tables
Go to Options, Settings and under the units make sure you have the vacuum unit base and the pressure unit base both set to atmospheric.
DaX
Post by DaX »
That fixed it! Thanks.
