Decimals on Sensor Overlay
zbrskz
Post by zbrskz »
Hi,
Sensors seem to default their number of decimals according to its "nature". Sensors like RPM, VSS, TPS, etc default to 0; MAP, Knock Level to 1 and others like INJ & AF to 2.
Is there a way to increase the number of decimals?, it would be quite interesting specially to sensors that return Volts. Actually on the sensors Window these sensors have 2 decimals where in the sensor overlay only one decimal is used which compromises analyses.
Thanks,
Luis
Re: Decimals on Sensor Overlay
Using the display window add a value gauge. You can change the decimals there.
zbrskz
Post by zbrskz »
Yes, I'm aware of that.
Unfortunately the sensor overlay doesn't follow the number of decimals one sets up on the display.
The sensor overlay is quite a powerful feature for detailed analitcs, together with the lambda overlay, but it's quite frustrating to find its functionality somehow castrated by issues like this one, or the lack of copy&paste as well.
Luis
