Traction Control best setup for drag ? for 2017 si
Civic 2016+ 1.5 Turbo
alex_hockey69
Post by alex_hockey69 »
What should the numbes is each table be put at?
Or should they all stay the same?
Re: Traction Control best setup for drag ? for 2017 si
Use the Mod for street launch.
alex_hockey69
Which is where and what exactly?
alex_hockey69
Lack of power after enabling Traction Control . Street mod
The car has no power till 4500rpm then full boost come on at 24psi which is pretty cool but not worth the power loss. I updated the software with the new traction control settings when I'm driving the car on sport mode cruise control on but not using it the car runs perfectly fine when I turn off the cruise control the car lacks in power like I said before. I am running the +6 psi full throttle shift. as a set up
alex_hockey69
Can anyone explain how Hondata traction control updated works exactly
Can anyone explain to me how this Hondata traction control updated supposed to work for car? When the cruise control is not enabled the car has no power up until 4500 RPMs then full boost comes on. When I turn off the cruise control the car runs perfectly fine
What launching or driving? Can you post a datalog and tell us when you see the reduction in power?
gtfrede07
Post by gtfrede07 »
Just had this occur with mine as well. Just now uploaded on lunch break and car gets to 8 psi and that is it until 4-4500rpm and restores full boost. No further details at this time. Also +6. Did not try hitting cruise control to see if any changes yet.
gtfrede07
Post by gtfrede07 »
No problems until the flashpro required the new firmware so it is definitely something with 3.4.1
alex_hockey69
Hondata wrote: Tue Jul 16, 2019 7:55 am What launching or driving? Can you post a datalog and tell us when you see the reduction in power?
driving. reduction in power all gears from the start till around 4500 rpm
alex_hockey69
gtfrede07 wrote: Wed Jul 17, 2019 12:00 pm Just had this occur with mine as well. Just now uploaded on lunch break and car gets to 8 psi and that is it until 4-4500rpm and restores full boost. No further details at this time. Also +6. Did not try hitting cruise control to see if any changes yet.
I am getting only 1psi until 4500 rpm
gtfrede07
Post by gtfrede07 »
I have returned mine to stock. Will only use flashpro to monitor the car until I sell the flashpro or decide what to do. I'm sick of being forced to beta test when it forces firmware updates that makes me reflash the car. Or else run the risk of the tune files not matching and leaving me stranded.
alex_hockey69
alex_hockey69 wrote: Wed Jul 17, 2019 3:39 pm
Any news ?
Found the problem, working on the fix. The work around is to switch on cruise control main.
alex_hockey69
Hondata wrote: Fri Jul 19, 2019 6:22 pm Found the problem, working on the fix. The work around is to switch on cruise control main.
Thanks keep me updated.
We're release the fix on Monday.
