HOW TO SET AEM WIDEBAND TO HONDATA DATALOGGING
hazetuning420
Post by hazetuning420 »
So I recently upgraded to a aem air fuel ratio gauge, I wired up the power n ground , than I left out the blue unhooked, but the white one I conected to pin d14 to ecu side, now I get reading on the wideband and ecu but they are both reading way off like the gauge would be 14.7 but on the laptop is reading like 1.6 not 16.0 but 1.6 how can I set up the wideband to match hondata on the laptop n gauge???
Im new to hondata so any help would be much apriciated
Charliek9
Re: HOW TO SET AEM WIDEBAND TO HONDATA DATALOGGING
Post by Charliek9 »
adjust the voltage offset. should be good to go. what aem afr are you using?
hazetuning420
im using the 30-4110 a\f ratio gauge, I connected to pin d14 not the d10 like I hear a lot of people talking about, now will that make a difference?
how do I adjust the voltage?
Do not use the d14 input as it cannot see the full voltage range.
