Hestitation @ Partial Throttle/Cruising
FlashPro questions & answers specific to the 2008+ Accord, Americas and international
snavelkar
Post by snavelkar »
Hello,
I recently installed the SiriMoto Flex Fuel kit along with the Hondata Tune. I'm experiencing a hesitation coming from the engine (almost like it's lurching or engine being starved at partial throttle - during cruising speeds). It's hard to entirely describe, but have you noticed anything like this in your 2.0T Accord running FlexFuel? Are there any updates to the tune to be expected?
I can send some datalogs if it will help.
Regards,
Sameer
2018 Accord 2.0T Sport | PRL Stage 1 Intake | PRL exhaust | Hondata FlashPro | SiriMoto E85 FlexFuel Kit
Re: Hestitation @ Partial Throttle/Cruising
Post your calibration as well as a datalog showing the issue.
I Hate Import Cars
Post by I Hate Import Cars »
I know this is an old post but did you ever get this figured out? My 2019 2.0T 6MT does the same thing after Stage 2 flash. I figured out yesterday that if I shut off cruise control all together the performance is WAY better and I haven't noticed that hesitation with ethanol anymore. Might try that out if you're still having the problem
KFactor
Post by KFactor »
Let me add a third person on here with the same problem...
I've had that problem for literal years now but found that holding the rpm a little higher keeps it from hesitating. I guess I've gotten so used to doing that I forgot it's actually a problem. The next time I use the cruise control I'll record a datalog unless someone beats me to it.
