FlashProManager 3.4.2
V3.4.2 (22 July 2019)
  • FlashPro firmware updated to version 165
  • [2015-2017 FK2 Civic Type R] Added secondary o2 disable
  • [2016+ Turbo Civic] Fixed 5AG-U71
  • 2016+ Turbo Civic MT] Fixed limited boost problem
  • [2017+ US Civic Si] Fixed limited boost problem
  • [2018+ Accord 2.0 MT] Updated to 6B2-A06
fusionbuzz
Re: FlashProManager 3.4.2
Post by fusionbuzz »
Thanks for releasing the update!
After I've updated Flash Pro Manager to 3.4.2, do I need to reflash the car (2019 HB Sport Touring)?
Yes you should always re-upload your calibration to the ECU after a software update.
nappco
Post by nappco »
Hi, can you explain the limited boost problem Civic 1.5L MT and what version of Flashpro did it become an issue?
It was only an issue on 3.4.1 and has been resolved.
gtfrede07
Post by gtfrede07 »
What's the story on the cruise control main?
Are you all implementing something new/ different?
The boost issue is gone that 3.4.1 had but i can feel the car relaxing/tightening when turning on/off cruise control main.... it feels as if it's changing the throttle target or the "padding".
It would be nice to know what we are "beta testing" so i can...
1) know what to expect
2) report things like this if there is an unknown issue
2018 si
With older versions the rev hang disable would not work so well when cruise control was enabled. So now the throttle response goes back to stock when cruise control is on.
gtfrede07
Post by gtfrede07 »
Nice. Thank you.
gtfrede07
Post by gtfrede07 »
Another question does this add rev hang back some when cruise control main is on as well?
Car is dialing in and starting to really run well.
Yes. Otherwise the cruise control has trouble.
gtfrede07
Post by gtfrede07 »
That is great news! Almost has 3 separate driving modes now at my disposal. That select ability of rev hang use was one feature the other company has that I was jealous of.
