VSA disabled in Flashpro TSX
kenmaster
Post by kenmaster »
I disabled VSA in flashpro for my TSX, but it didn’t do anything after I flashed it. Still have to press the VSA OFF button to turn it off every time I started the car. Any help would be appreciated TIA.
Re: VSA disabled in Flashpro TSX
What year TSX are you referring to?
kenmaster
Post by kenmaster »
04, but using 07 ECU.
Disabling the VSA in the software does not fully disable it. You must still disable it via the switch in the dash.
kenmaster
Post by kenmaster »
So what exactly it does when disabled it in the software?
It stops the ECU from acting on the communication from the VSA to close the throttle & retard the ignition. It was put in there for race cars. If you still have the VSA module then eventually the VSA gets upset and starts to throw errors or restrict engine output.
kenmaster
Post by kenmaster »
Ok I see. No wonder sometime the car the throwing the VSA errors. Had to restart the car then it went away LOL.
