"Notch" at 2300-2400 rpm in 6th Comfort Mode (only)
Charlie Brown
Post by Charlie Brown »
I have a "notch" around 2300-2400 rpm when in sixth gear - power drop that feels exactly like when an A/C switches on. It happens irrespective of the acceleration (ie, will do it even when just gently accelerating. It's only in 6th (might also be in 5th but have not noticed it) and only in comfort - and it's not in the map -- I've tried the stock map as well as the standard Hondata 93 Octane map. I can't say if it's recent or if it has always been this way (I typically drive in Sport).
Question: Anyone else experience this power drop in Comfort in 6th when around 2300-2400 rpm with a Type R (mine is a 2018)?
Re: "Notch" at 2300-2400 rpm in 6th Comfort Mode (only)
Have you made changes to the torque tables for comfort mode?
Charlie Brown
I have uploaded three different tables: untouched "Stock", untouched "Hondata 93 octane), and my own (with modified tables). They all have this same "notch" in sixth in comfort.
Post your calibration as well as a datalog made with that calibration that shows what you are describing.
