Rev Match System Problem
If you get a 'Rev Match System Problem' and an 'Emission System Problem' then don't tell us those errors. Rather we need the actual error code.
Those errors mean that the rev match sub system has disabled itself because of some other error. They are symptoms of some other problem and don't tell us anything about what the problem might be.
So plug in your FlashPro and read the error codes from ECU. If the ECU has no errors then the problem is with some other system (ABS etc).
