B20V 440cc Injectors Refusing to Idle on Any Basemap
LoGiiKz_x_K1LLA
Post by LoGiiKz_x_K1LLA »
I have a freshly built b20V with a B18C5 head running on 440cc from Ebely. GSR cams and Low compression pistons with H-beam rods. Below is the most successful calibration. Maybe i did something wrong. But the motor wont stay idling and shows no vacuum. I have oil pressure but little or no vacuum.
Re: B20V 440cc Injectors Refusing to Idle on Any Basemap
The calibration is set to 240 cc injectors. You need to set them for the correct size and dead times.
LoGiiKz_x_K1LLA
Turns out it was the Distrubuter that i got from amazon. Now i have run into another problem however. When trying to go up hill the car feels like it has no power. If i get a running start i can make it. If im currently on the hill then it just wants to stall out. I can attach a different calibration that i was trying to adjust today. Just gotta pull it from my other computer.
LoGiiKz_x_K1LLA
Here is the Calibration.
Post a datalog showing the issue as well.
