Latest Hondata App (Android).. Need a little help
Dantastic
Post by Dantastic »
Under Sensor Settings...How do you enter a negative number? My tiny brain just can't make it work. I've tried different keyboards (Google PC will show +, -, etc.) but the app will not accept the "minus" character. I tried to copy/paste from a different sensor (which had a negative number) but this method also fails (no matter from what source you copy a negative numeral).
Is there something obvious I'm missing?
Other than that the app seems to work just fine.
This is on a Samsung Galaxy Tab S3 running Android 8.0.0.
Re: Latest Hondata App (Android).. Need a little help
What sensor and what value?
Dantastic
Post by Dantastic »
Intake Manifold Pressure. Using the "/PSI unit. This would normally range from negative 30" Hg (a perfect vacuum) then swap to PSI on the positive side (which for me is about 30 psi).
You can try it out on Timing Advance as well. This is already set at -50 to +50 degrees. I'm unable to input a negative value there either. So if you clear out the preset "negative" sign you can't get it back.
Is this the paid app?
Dantastic
Post by Dantastic »
Yes. A reasonable $7.99
App has been fixed and should be a day or so before Android releases it.
Dantastic
Post by Dantastic »
Thank you for your efforts. Much appreciated.
