AFM.v reads zero
Civic 2016+ 1.5 Turbo
NikkoPH
AFM.v reads zero
Post by NikkoPH »
Hello All,
Did 3 datalogs today and AFM.v stays zero volts all the time.
Im using flashpro on a 2017 civic si. Software and firmware updated.
Trying to calibrate my AFM as my fuel trims are over 10%
gtfrede07
Re: AFM.v reads zero
Post by gtfrede07 »
Afm voltage is not log-gable on the SI due to the MAF design. AFM vs Strim is what I use in the scatter plot and line up the g/s numbers to the table cells.
NikkoPH
Post by NikkoPH »
Thank you for that information, i was hitting my head for no reason.
My graph shows +10% across the graph. Please correct me if i am wrong but i should adjust the g/s around -10%?
gtfrede07
Post by gtfrede07 »
correct. then smooth out the surrounding cells on each end of your adjustment. I usually go half to 3/4 of the trimming percentage to prevent over shooting the adjustment. So instead of the full -10% I would do maybe -7 or -8%. Completely up to you.
The 2017+ SI does not use voltage for the AFM, instead it uses frequency.
NikkoPH
Post by NikkoPH »
gtfrede07 wrote: Tue Aug 13, 2019 9:42 am correct. then smooth out the surrounding cells on each end of your adjustment. I usually go half to 3/4 of the trimming percentage to prevent over shooting the adjustment. So instead of the full -10% I would do maybe -7 or -8%. Completely up to you.
Got it, i was thinking of doing 3 increments, ill 7% and take it from there.
Spunkster wrote: Tue Aug 13, 2019 10:12 am The 2017+ SI does not use voltage for the AFM, instead it uses frequency.
Got it! Thank you for all your help!
NikkoPH
Post by NikkoPH »
Datalog my commute today, around 91 ambient temp and really traffic. Here is what i found, my strim is around +18 across the board. It used to be +10 and i decreased by AFM by -10 yesterday prior to my commute today. Im surprised that s trim increase! What am i missing here? I don't wanna be running lean the whole day tomorrow.
Thank you!
gtfrede07
Post by gtfrede07 »
miscommunication if its trimming positive you need to add to the afm number.
gtfrede07
Post by gtfrede07 »
Jesus that plot is all over the place. I would highlight that whole table and increase +15% and re datalog.
gtfrede07
Post by gtfrede07 »
As flat as the mean is I would almost suggest +20 and re datalog. Thats just a big swing in one go. Try the 15% and see if it still wants added to.
TO CLARIFY BECAUSE I CANT EDIT THE ABOVE POSTS IF S.TRIM IS A POSITIVE NUMBER YOU SHOULD INCREASE THE AFM NUMBER
IF ITS TRIMMING A NEGATIVE NUMBER YOU DECREASE THE AFM NUMBER.
NikkoPH
Post by NikkoPH »
gtfrede07 wrote: Thu Aug 15, 2019 5:03 am As flat as the mean is I would almost suggest +20 and re datalog. Thats just a big swing in one go. Try the 15% and see if it still wants added to.
That is where i got confused, i have reloaded the +6 calibration and adjusted +10.
NikkoPH
Post by NikkoPH »
gtfrede07 wrote: Thu Aug 15, 2019 4:49 am miscommunication if its trimming positive you need to add to the afm number.
To clarify, if the STRIM is within negative values i should adjust by putting a (-) negative value towards zero and if its within positive value i should adjust by putting a (+) positive value towards zero. Please correct me if i am wrong
negative trim means it is removing fuel because it is too rich and you need to lean it out.
positive trim means it is adding fuel because it is to lean and you need to richen it up.
NikkoPH
Post by NikkoPH »
Spunkster wrote: Thu Aug 15, 2019 11:25 am negative trim means it is removing fuel because it is too rich and you need to lean it out.
Hi spunkster, i got that concept. Base on the graph i attached i need to richen up. My question now is should i be adjusting the AFM or g/s in the calibration?
Thank you!
It is the same idea as what is in the help file: https://www.hondata.com/help/flashpro/t ... m_flow.htm
