Unit Change Won't Save
Emount91
Post by Emount91 »
In version 1.0.6 of the Hondata mobile app for iOS (new app, $5.99 in the app store), when you change a sensor's units the change does not save after you close out of the application.
Specific example is Boost Pressure: The app defaults to mbar. When I go into the settings and change the units to PSI it works. Once I close out of the app and reopen it, the units revert back to mbar. This seems to be the same with every sensor that uses PSI/mbar as a unit of measure.
All other changes to the settings seem to stick (which sensors you want on the dashboard, the app theme, etc).
Is it something I'm doing wrong or is this a bug?
Re: Unit Change Won't Save
App has been submitted to Apple; should be a couple of days.
Emount91
Post by Emount91 »
thanks guys!
Emount91
Post by Emount91 »
The update hit the app store today, version 1.0.7 fixes the above problem.
Thanks again, guys!
