Target Lambda Issue
Themyth
Target Lambda Issue
Post by Themyth »
Has anyone ran into a issue with their target lambda being highlighted in red? And the percentage +/- value (highlighted in Blue) is a incorrect value during target overlay? The chart use to be separated by 3 different colors. I've changed values in the settings and sensor settings to make all match. Doesn't matter if its in KPA or PSI.
Re: Target Lambda Issue
Post your calibration please.
TTR
Post by TTR »
The values in the table are 87.00, I think you want .87. 87 is much higher than 1.00 which is why they're red. If yo change the values from 87 to .87 the color will change.
Gerry
Post by Gerry »
TTR is correct. Lambda is measured as 1.00 1.01+ or .99-. putting 87.00 is way too high and the program see is and is telling you to correct it. if youre looking for an afr of 12.79 then you need to enter in .87
