Turbo Xs blowoff valve flash pro info
Civic 2016+ 1.5 Turbo
Rc100722
Post by Rc100722 »
2019 civic si use And want to purchase flash pro and currently have turbo Xs blow off valve and kn intake will I have any problems running flash pro with turbo Xs blow off valve
Re: Turbo Xs blowoff valve flash pro info
It depends on the blow off value. If it is internally recirculating then it will work. If it vents to atmosphere then it does not matter if you run FlashPro or not; the ECU will not be able to meter the air accurately.
